Results 1 to 7 of 7
Thread: Carb Rebuild Help 85 Big Red
    Minneapolis
    31
    I have been working on my carb tonight and I seem to be missing the primary nozzle under the primary jet. It shows the part in the carb diagram but it wasn't in my carb. I am using the Moose rebuild kit. I do have a small rubber tube left from the rebuild kit. It is approx. 1" long x 1/8" thick. It is about the right size and fits where the primary jet goes, just doesn't make sense because it is rubber and would just collapse if the jet is tightened down on it. In the diagram picture the primary nozzle looks like a metal part. Am I missing something? Thanks
    Mar 2008
    EastGreenbush, newyork
    3,494
    i had the same problem man. your only option is to find a parts carb to rob this nozzle from. thats what i had to do. first time ive seen anyone else with this problem. whoever had it apart in the past must have dropped and lost it. I didnt mind though, it saved me 200.00 on the bigred cause the seller could not get it running. heres the thread i started on ithttp://www.3wheelerworld.com/showthread.php?93058-Carb-Rebuild-Shocker!!HELP!!got-pic-up&highlight=
    Mar 2008
    3,494
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    I have a couple of rebuildable big red carbs for sale. $45.00 each, shipped to your door.
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    Pacific NW
    4,255
    I think that plastic tube is a safety shipping cover for the
    delicate air needle screw.
    Kinda looks like a hollow black pencil lead sized piece of
    shrink tubing?
    The only odd thing I remember is that there is an emulsion tube under one of the
    screw out/in jets.
    Brass, about an inch long with holes along the sides and it gets plugged
    with crud.
    I missed it 2x since it's down inside the internal passage under the jet that can be screwed out.
    Minneapolis
    31
    That makes sense for the little tube, it was over the needle screw. I am definately missing the primary nozzle, the primary jet screws into the carb body alot farther on mine than in the diagram pictures.
    Oct 2007
    Minneapolis mn
    4,067
    Let me know if you need any help... I have rebuilt a few BR carbs... (just up in Maple Grove)
