chain
i was wondering, when you rebuild the top end on a 250es big red, do you usually replace the chain too? i have the cylinder reworked and he head, so i was wondering about this before i put it back together.
I am doing my 200x now, valve seats/piston/bore, I am putting in a new DID chain and tensioner, $35.
ok where did you buy your chain? i say one place that charged 200 for a chain.
The dealer, denniskirk.com, bikebandit.com, ebay.com they are everywhere. And yes when you do a top end on a 4 stroke you should replace the timing chain, it's cheap and a sure way to know that you have a good chain going in a good motor.
Foolin'
i have the piston off and the right case cover i need to know how to take off the clutch? the manual sais you have to have a tool to help you hold the clutch. then you need a clutch puller.
is this true? i am kinda stuck with all the parts just dont know how to put the chain on.
i think i need help on this one. the manual sais youhave to touque the nut to like 70 pounds. dont know if i can get this off.
//ArrowChat Integreation Code
