I have the trx 9 inch rims. So either I'm going with a 18x10x9 or a 20x10x9. Will a 20x11x9 fit that rim as well. Where is a good place to get a affordable 18 or 20" tires?
1978 ATC 90
22mm Keihin carb
Ported intake/head
Performance cam
56mm 9.5:1 piston
110 cylinder/crank
110 cylinder/ timing chain
Front drum brakes
Brush guard
Complete rebuild to a 122cc
Complete frame off restoration.
$1400 invested
1983 ATC 110
22mm carb
Ported head/intake
Performance cam
56mm 9.5:1 piston
Complete rebuild to 122cc
$1000 invested
1984 200x
26 mm carb.
CR85 rear caliper
TRX hubs/rims
$871 invested
Well what do you plan on doing? If it's life has some use on the trails, then go for 20's, but if it's strictly a racer, then go for 18's.
LED obsessed
2015 Yamaha FJ-09
Not a racer. Its for on the ice and trails.
1978 ATC 90
22mm Keihin carb
Ported intake/head
Performance cam
56mm 9.5:1 piston
110 cylinder/crank
Front drum brakes
Brush guard
$1400 invested
1983 ATC 110
22mm carb
Ported head/intake
Performance cam
56mm 9.5:1 piston
$1000 invested
1984 200x
26 mm carb.
CR85 rear caliper
TRX hubs/rims
$871 invested
Split the difference and put 19's on mine.
I'd go for 20's if you're going on ice and trails.
LED obsessed
2015 Yamaha FJ-09
Can you fit a 20x11x9 on a trx rim?
1978 ATC 90
22mm Keihin carb
Ported intake/head
Performance cam
56mm 9.5:1 piston
110 cylinder/crank
Front drum brakes
Brush guard
$1400 invested
1983 ATC 110
22mm carb
Ported head/intake
Performance cam
56mm 9.5:1 piston
$1000 invested
1984 200x
26 mm carb.
CR85 rear caliper
TRX hubs/rims
$871 invested
20" tall x 11" wide x 9" rim. - I don't see why it wouldn't fit...
If you have Bought a item from me, Please leave me feedback
If your buying a item from me check my feedback
Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
Yea the 20's will fit on those rims, I have a set of Razr's on those rims. I had 18x10x8 Holeshots on my 200X with 14 tooth front and it was perfect. I felt anything bigger affected the handling and performance of my 84 200X. But it's a personal preference. For the trails 20's will work great and will do fine on the ice. If you are looking to do some serious ice racing you will want a 18" Turf Tamer and about 320 Kold Kutters per tire to be exact![]()
Foolin'
20x11-9
20 is the overall diameter of the tire
11 is the width in inches
9 is the rim diameter
18" tyres will give you more snap in the bottom of the gears, but 20's will give better all around use and stay pretty close to true top end speed. I personally have run both 18's and 20's 18's are great for places where you don't need top end but want more get up and go, and 20's are great for places where your speed is constant and you don't return to the bottom end too often.
WARNING: I'm About To Do Something REALLLYYYY Stupid!!!
Past:
'82 Honda 110
'82 Honda 110
'83 Honda 185s
'85 Honda 200m
'85 Honda 250sx
'85 Honda Auto-X
Present:
'82 Honda 250r
'82 Honda 250r (Basket Case)
'83 Honda 200s (Parting out)
'84 Honda 200x
'84 Honda 250r (Basket Case)
'85 Honda 350x (currently being built)
'85 Honda 350x (waiting to be built)
Future:
'83-'87 200x's (wish list)
'86 Honda 350x (eventually)
20's, or 21" mudsharks.
Stock rims and 20" tires from a 400ex or z400/kfx400/dvx400 bolt right on
Rob
I run a set of 20" Carlisle Badlands on my 200x for the woods trails around WI. They work fantastic and are a great woods/trail tire. I have a set of 18" fastrekkers that I ran ONCE in the woods, lots of abuse to the skid plates and sprocket. I am going to fill them with screws for ice riding.
YTM-200, Wheeling machine!!!
1985 Honda 200x...
...Just a simple mild 200x
