So, I blew up my trike when my piston skirt blew off from alignment. This is due to worn crank bearings and a loose lower connecting rod bearing. My engine is stripped right down to cranks. How do I seperate the two crankshaft halves? I put iton a press with no success after heating and what not. Does anyone now where to get cheaper crank bearings and wristpin bearings? Wanna get his bad boy back on the road!![]()
