If you mean that you lift the lever up and the lever falls back down on it's own when you pull the engine over, that's what it's supposed to do. At least the ones on the two that I had always did this. If it didn't automatically fall down, the engine wouldn't have enough compression to start.
and try to grab it with a pair of Vice Grips to remove it and then replace it. I think Yamaha still sells them. Get a new O-ring too. The screen cage can be cleaned and reused. Make sure there's no burrs and don’t over tighten it or use sealant.
