Results 1 to 11 of 11
Thread: 350x rims
    Apr 2003
    Bay Area CA.
    2,638
    350x rims
    what rims for the 350x do you guys think look the best and perform the best? i want some new rims :-D
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    86350X is offline At The Back Of The Pack Arm chair racerFirst time rider
    I have had no problems with the stockers, but I am currently running "86 250R rims in the rear with holeshot XCT tires and the gold rims actually look pretty nice on the bike
    2003 honda shadow 1100 spirit
    94 XR600R
    70 qa 50 with a 90cc motor in it
    87 XR80R
    82 XR500R
    1972 Honda z50A mini trail,,, Finally got a stock mini
    1981 CR450R
    2004 chevy silverado ls ext. cab 4x4 5.3L
    Fresno Ca
    2,695
    any cromed or well polished rim will look good (even stock) just look through a magazine and see what you like
    Apr 2003
    Bay Area CA.
    2,638
    when looking for rims for the x is there a certain size or something so i know that they will fit the x? ive never bought rims before :oops:
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Fresno Ca
    2,695
    depends are you going to use the same tiers or buy some ones with it? if your going to use your old tiers then you have to get the same rim hight as your old ones. then its just down to looks. the bolt pattern has to be a honda bolt pattern (whitch is extremely common) also you have to think about the thickness of the rim that you want the thicker it is the stronger its going to be. if you do alot of jumping then get a thicker one. drag racing get a thinner one.
    Apr 2003
    Bay Area CA.
    2,638
    ya ill definetly be getting new tires for new rims. so when i look for them online or in a mag i just look for rims that are the honda bolt pattern and theyll fit my x?
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Fresno Ca
    2,695
    is your X a honda?? lol you have the same bolt pattern as a 400ex (i belive its 110mm but not positive)
    ITP rims, they look good and they have a couple different styles. and their tough. I've thumped on mine and their holding up great.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Jun 2003
    South of Rochester, NY
    3,471
    The rear hub size for a 350X is 4/110 pattern (4 studs, 110mm apart.)
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Apr 2003
    Bay Area CA.
    2,638
    ya im thinking about the ITP T-9 aluminum wheels. they look nice.
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    May 2002
    Cortland, NY
    1,195
    You should get the ITP C-series rims, they look killer!
    http://photos.yahoo.com/dynofox250 (TF 03 pic's)
    Trikes: Restored '86 ATC 250r, original and mint '83 185s
    Quad: '86 TRX 250r
    Sled: Rev X 800ho mod
    Bike: '00 ZRX 1100
    TF '03 and '05 Survivor
