Thread: 84 250r front end on a 86 200x??
    matt86200x's Avatar
    matt86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Canada Eh!
    366
    Will this work? I bent a fork on my x and front end was fairly beat up to start with. If welding new stearing stops is the only thing thats fine.
    85 250sx
    86 300es in the making
    86 200x
    86 350x
    Willamstown PA
    5,824
    all you need to do is bore out the old 200x tripples and slid in the 250r forks. u dont need the tripples. also the 83-84 250r front caliper, wheel and disk brake is the same as the 200x stuff.
    matt86200x's Avatar
    Apr 2009
    Canada Eh!
    366
    how much will i need to bore out the 200x tripples?
    85 250sx
    86 200x
    86 350x
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    I am not sure about the tube diameters but I believe the tripples will bolt right on and you will not have to bore anything. I have put 200x fronts on 81Rs and it is a simple bolt on swap.
    EDIT: I just realized you said 86 model. I have no idea??
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
