The carb from an 86 200x will fit, you will have to use the throttle head(body?Screw? The needle and part that screws in the top of the carb). It gave my high comp, cammed 200S a good bit more low end, and helped on the speed.
I found it was alot easier, and alot better to take the whole thumb throttle from the X and put it on the 200S, it'll require taking a file or something and cutting a small peice off the side of the thumb throttle box, and the small metal nub on the handlebars.
It's COMPLETELY worth it though compared to the stock throttle.
