Results 1 to 15 of 26
Thread: ATC110 Smoking
    May 2011
    Wichita, Kansas
    48
    ATC110 Smoking
    Hello, My 1982 ATC110 is smoking pretty bad with white smoke. It smokes while you are not throttling it at all, then when you throttle the smoke stops, but when you stop it starts again. Im not sure what to do with it, I read that if you have the top end sent it they can reuild it and it will stop smoking. If any of you guys know what to do, i would appreciate the help. Thanks.
    Mason
    May 2011
    Walworth, NY
    122
    Hmmm. Oil is typically blue smoke, which rebuilding the top end probably won't fix. It sounds like you are burning (boiling, actually) water somewhere in the system and its coming out your exhaust. You take it through any water lately? It been sitting outside?
    May 2011
    Wichita, Kansas
    48
    Nope, its been in my garage. Just changed gas, oil, spark plug. I bought it from a guy who said he had kept it in his shop. Thanks
    Mason
    honda4h's Avatar
    honda4h is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ottawa ontario
    361
    id take it for a good long drive white smoke is ok its just moisture in the muffler. blue is bad.
    Pacific NW
    4,255
    To address your rebuild question, I think there is a
    valve seal on the exhaust valve that can cause excessive oil
    consumption and blue smoke and might save you a rebuild.
    White smoke is a different story. Does it smell like anything in particular?
    1,736
    just because its white does not mean its not oil. I agree, get it real hot and boil off any moisture it has, but chances are its time for a rebuild anyway, these old trikes are all long over due by now.
    your going to want to bore it to the next size up to get a fresh cylinder surface and a new piston with rings to the new size of the cylinder.
    (well you generally match the cylinder to the new bigger piston you get but you know what im saying)
    May 2011
    Wichita, Kansas
    48
    Thanks everybody. I am new and don't know much about these things, and I really appreciate all your advice. Are you talking about sending it in and having the people over bore it? Because i have no clue how to do anything like that. Thanks!
    Mason
    1,736
    yes, your local Honda ATV dealer or machine shop could do it.
    May 2011
    Wichita, Kansas
    48
    Alright, thanks a lot for the information.
    Mason
    Grande Prairie, Alberta, Canada
    96
    About the boring... I could not find a shop in my area that was even remotely interested in boring a jug. And that includes the honda dealer. I ended up doing it myself with a hone. It's trickey work so if your not confident then don't do it. Good luck finding a shop to hone it for you. Should be easier for you in wichita than it was for me in the middle of nowhere.
    1,736
    thats weird, i have 3 local shops 30 mins drive either one who would do it.
    jadleybray's Avatar
    jadleybray is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    oregon
    352
    Quote Originally Posted by H2Sbass View Post
    Are you saying that you needed a bore and used a hone instead?
    Coldwater, MS
    208
    He is in canada..... That may be the difference.
    Since they outlawed 3 wheelers..... only outlaws still have them!
    1885 Honda 200M (sold to father-in-law he rides it everyday)
    1982 Honda Big Red 200E (near mint)
    1998 Kawasaki Lakota 300 (daughter's)
    Tionesta, PA
    5,747
    Quote Originally Posted by jadleybray View Post
    I was thinking the same thing. He says it is tricky work - I believe that. That would be some trick boring a cylinder with a hone.
    May 2011
    Wichita, Kansas
    48
    Yeah... don't think ill be doing that. Ill try to find a shop around me to do it. I let it run for 30 minutes, it is still smoking but not as bad. Thanks for all the information.
