Thread: ATC 110 Tank Compatbility?
    Cold Lake, Alberta, Canada
    3,019
    Trying to fix up an '82 110 for a friend. The tank is rotted out on both bottom edges. What other years tanks are compatible with this model year? I would like more options of finding one other than just an '82 if possible. Thanks in advance for the help!
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    6,804
    1970-82 will all fit and still look correct with your seat .
    3,019
    I tried a 72/73 tank on it last night but the CDI box(?) is in the way. There is an indent on the inside of the '82 tank to accomodate this electrical device.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    6,804
    Cut the cdi tab off the frame and relocate the cdi to use an older tank other wise if you dont want to do that the 81/82 is the only tank that will fit that model .
    3,019
    You are absolutely correct Shortline. I tried fitting it up again last night and it worked great, thanks!
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
