Thread: Help with Chain Slide and Airflilter
    Lewiston, N.Y.
    1,479
    I have 2 questions. What is the difference (on my 350x) between the chain slide (rub block?) and the chain slider?
    #2 - What brand of airfilter do people prefer...UNI or K&N?
    Thanks!
    Jim
    1) One goes over the swingarm and the other bolts below it (to the frame) when the chain is not pulling. Both are discontinued.......
    2) I like Uni oiled because I ride with my lid off and in muddy/wet/dry/sand/rocks etc etc. I think the UNI traps finer particles; Some will say a properly cleaned K and N works as well and breathes better. To each there own......
    newfane ny
    1,277
    here are the chain slide and rub block i use, excellent product http://motors.shop.ebay.com/i.html?_...506.m270.l1313 i will use them on my next 350x build also
    Lewiston, N.Y.
    1,479
    Thanks for the responses guys. I finally got the carb dialed in and went mudding 2 weekends ago. Will post up some pix this weekend.
    newfane ny
    1,277
    jim you should come out to attica to ride trails and huge sand pits its a blast, glad to see you have it running good
