Results 1 to 11 of 11
Thread: My 1985 200x is coming along!
    May 2011
    Colorado
    51
    I just finished putting her back together the other day. Tell me what you think! she smokes like crazy though....any suggestions on good engine rebuilds? Click image for larger version.
ID:	124144Click image for larger version.
ID:	124143Click image for larger version.
    Crest California
    3,014
    Smoking like crazy? Time for a rebuild, probably will cost you around $70 or so to get the cylinder bored out to the next size, and anywhere from $150 to $200 for a complete piston/gasket kit. Could all be done very easily in a day or two. Also don't forget the cam chain and tensioner.
    LED obsessed
    2015 Yamaha FJ-09
    May 2011
    Colorado
    51
    where can i get it bored to the next size? and where is a good place to buy the piston/gasket kit...how hard is it to put the piston and gaskets back in it then? could you explain alittle more in depth...sorry im learning about engines right now..sorry!
    Crest California
    3,014
    Call around some of the local motorcycle shops, one of them has to have a boring machine. As far as re-assembly, it's fairly straight forward, exactly the opposite of how you dis-assemble the engine. Don't forget to properly torque down the head bolts in about 5-6 rounds- don't torque them all the way down the first time.
    LED obsessed
    2015 Yamaha FJ-09
    May 2011
    Colorado
    51
    ill have to give some shops a ring in the morning. what about the piston and seals any suggestions? and how much should i bore it? whats the next step i guess from the 200 stock bore.
    Crest California
    3,014
    You need to have the inside of the cylinder measured BEFORE you purchase a piston size. From there, you will know what size piston you need to get (65.5mm, 66mm, ect. ect.) as well as what you need to have the cylinder bored out to.
    Stock bore on the 200x is 65mm, I THINK, not 100% certain. If it is 65mm, then 65.25mm would be the next size up.
    LED obsessed
    2015 Yamaha FJ-09
    May 2011
    Colorado
    51
    okay so i rip the top end off basically where the piston slides in and thats what i get bored and then once the new piston kit and seals and once the engine is bored just throw everything back in...sounds simple! okay thanks so much will this do anything to performance of the engine?
    Apr 2009
    Parker, CO
    607
    Depends on how clapped out the engine is currently. Fresh top end can really make the engine feel peppy again. With the 200x you will have the cam chain,valves and timing to deal with. Should download a manual if you haven't already.
    Mar 2011
    W
    107
    I recommend buying a wisco set off of dennis kirk they have really good prices and ship it to you within 3 days or if you can't wait next day delivery is avaliable. Just type dennis kirk in google and search by make and model on the left side Hope this helps.
    ctbale is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    anchorage alaska
    289
    to do the work, you pull the whole motor and put it on the bench. (I hope you do, I did! HA!)
    I am in the middle of doing my overhaul now, piston rings bore valves, t chain and tensioners, kickstarter mod. before you take it apart, move your pulsar up and down to see if your cam journals are worn out. http://www.youtube.com/watch?v=FF_HZcGUiG8
    Bustos82's Avatar
    Bustos82 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    Coolidge, Arizona
    447
    looking good man. like the tank....
    A veteran is someone who, at one point in his life wrote a blank check Made payable to 'The United States of America' for an amount of 'up to and including my life.' That is Honor, and there are too many people in this country who no longer understand it.
