Thread: can some one help me with my build
    jr315rn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2011
    rochester ny
    288
    i just got a 1982 honda 110
    im looking for mods with frame, motor, etc
    any help with this would be great also i have rust in the tank, how do i get it out?
    what parts can be swaped with the one ten , such as forks etc?
    jake
    Oct 2007
    Minneapolis mn
    4,067
    Try the search button... There are alot of sweet 110's on the forum here...
    May 2011
    rochester ny
    288
    i really cant find any sorry im new to this forum
    6,813
    Here ya go !!!! Read and learn LOL .
    http://www.3wheelerworld.com/showthr...110&highlight=
    http://www.3wheelerworld.com/showthr...!!!&highlight=
    http://www.3wheelerworld.com/showthr...deo&highlight=
    Quote Originally Posted by jr315rn View Post
    Finger Lakes Region, NY
    613
    Welcome jr315rn! The gas tank cleaning has been posted a lot here with different methods that all seem to work. The Search box is top right of this page. Okay, I'll try and save you some time as you are searching many things. I took a few small pieces of chain, five-six links each and dropped them into my tank. Added some diluted muriatic acid and let sit for a while, shook it up, etc. BE SURE IF YOU USE muriatic acid you are outside or in a WELL Ventilated area as the fumes are Very Harmful and wear rubber gloves and proper breathing mask. Some people have used 1/4" - 3/8" nuts and tumbled them around for a while but the chain links are easier to remove and just as effective in my opinion. I used 50/50 half water half muriatic acid. Other members used stronger mixes and a few straight. Also remove the petcock first so you don't damage any screens/filters etc. (not sure what the 110 has in it). It really depends how bad it looks inside your tank. If I do another I'll go 75/25 water as I had some debris still kicking around the first few tries. My tank looked pretty clean when I was done! Hope this helps.
    ...the branch cannot bear fruit of itself, unless it abide in the vine...
    May 2011
    rochester ny
    288
    thankss u guys for the help.
    anyone know if there is a way to swap out the front forks from a 185 or 200 on to the 110?
