Results 1 to 13 of 13
Thread: Are All Balls or "Ebay Special" bearings crap
    Jan 2011
    earth
    57
    Looking to change out my rear wheel and swingarm bearings. Oem bearings are expensive.
    Is oem worth the price?
    If anyone wants to share their experiences it would be appreciated.
    Walters, OK
    104
    all balls work pretty
    Blossvale NY
    4,563
    I put a set of All-Balls swingarm bearings in my Quadsport 2 years ago. Got them through Rocky Mountain ATV.. BUT, I also installed a zerk so I can grease them periodically. That aside, they are working just fine for me....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Abrams, Wisconsin
    739
    i put some generic ebay bearings in my tri z a few years ago. just changed them again, but the were still o.k., just figured while i had it apart i'd put new ones in. went with all balls this time. so far so good, bit it's only been a few months.
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
    Dec 2010
    Pennsylvania
    510
    i have had good luck with the all balls bearings
    NEPA
    7,051
    All balls are fine. There ARE complete junk out there,If they're too cheap,leave em sit! I sell Quad boss and others,all great quality,,but back in the day,,I have had junk that broke installing them! True! That taught me!
    Masshole
    2,191
    My advise on any bearing you buy whether cheap or expensive, without grease their time is limited.
    Pop one of the seals off and pack them, you will be surprised how little grease they come with.
    If possible like another said, a grease zerk is worth its weight in gold, just remember to pop off the seals on the bearing on the inside so the grease can find its way in.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,249
    the BIGGEST reason for early bearing failure,, sideloading....... make sure the pipe between is the correct length!!! even cheap bearings last if properly installed
    NEPA
    7,051
    ^^ X2! ALWAYS measure your spacer tube,they are usually wasted ,guaranteeing a bearing job way too soon in the near future.
    Saskatchetoon Sk
    360
    All Ballz was the kit i put in my DX and they seem ok. I did repack the bearings before installing. One thing I have always done
    1982 Honda ATC 200
    1984 Yamaha 225DX
    Quote Originally Posted by jeffatc250r View Post
    I do the same thing Jeff.
    South Wales, U.K.
    525
    All balls are ok, but carefully pop out the seals on axle and swinging arm bearings and pack them with grease!! they will last longer and keep more water out..
    If it ain't sideways......what's the point!!
    86' Honda Atc 250R - under restoration
    10' Polaris Outlaw 525s - my XC race quad
    05' ATK 640 "Cannondale" xc racer
    00' Banshee 350
    Oct 2006
    Titusville, FL.
    631
    All Balls Bearings are top notch, probably the best aftermarket bearing availible!
