i have a gas in my oil what could it be. help
What kind of bike? If it's a 2 stroke then could be bad crankseals...if it's a 4 stroke then it could be the rings are bad (and it would also smoke like crazy) or you flooded the motor at one point. If you provide as many details as possible it is much easier to diagnose problems, or at least attempt to help diagnose problems.
Foolin'
on 4 strokes is their a carb overflow that goes into the crank case?
I have never seen a carb overflow go into the crankcase. There is a crank breather hose that comes off the crankcase though.
Foolin'
You flooded it.
Or a bad headgasket. That happened to my zero turn mower. The oil level kept rising. I have heard of leaking oil and burning, but never making oil. I figured out the headgasket was blown. I cracked her open and there it was. A small spot in the headgasket. Replaced the gasket and good as new. I got lucky since it was a 2 cylinder that I guessed the correct head.
Since they outlawed 3 wheelers..... only outlaws still have them!
1885 Honda 200M (sold to father-in-lawhe rides it everyday)
1982 Honda Big Red 200E (near mint)
1998 Kawasaki Lakota 300 (daughter's)
Turn your petcock OFF after every ride when you park the bike... If the gas is left on it can fill up the carb, run into the intake and into the cylinder, then the gas will seep past the rings into the crankcase... I had a 83 200x that did that everytime if you didnt turn the gas off, and I bought a 87 ysr50 one time that sat in a shed for 10 years and the crankcase was full of gas, the tranny was seized up because of it.... ITS NOT A MYTH it does happen!!
Machines owned:
85' atc250r (sold)
85' 250sx- the daily rider
85' 250sx- building w/ fourtrax 300 engine
83' Alt125- the Beast
85' atc70
83' atc70
01' yamaha wolverine 350 yz blue(only bike i ever bought new)
SILLY RIDER! TRX IS FOR KIDS!!!
FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
86 250R
86 350X
87 250sx
85 200x/cb350 custom
81 185s/200x/250r custom
79 atc 70
Mini-Trail z50, 110cc Pit Bike
and many multi-wheeled machines
Put a new needle and seat in it,problem solved for another 20. It could be simply dirty,but when you can't even tell us the year and model.....
X10 with atcRacer and Thorpe
I almost ruined one of my fav bigreds.
Float valves should not be trusted
and 'off' on the fuel petcock is not always off.
I always make sure fuel off is actually off.
Fuel can run into the cylinder and dilute the oil.
even if its just running rich enough it can do that, the excess fuel washes the oil of the cylinder and lets compression by and unburnt fuel past the rings, into the oil, is it fowling the plug?
^ what he said.. still its good to turn it off.. that's why they put it there.....
