Results 1 to 7 of 7
Thread: sprocket questions for my extended swinger on the 86R
    STL
    3,560
    Whats the recommended amount of teeth on the front and rear sprockets? The swinger is plus 6inches and im just trying to figure out what I should run. I want the bike to be all around use, not really just for drag racing but I still want to be able to drag it and trail ride it.
    what do you guys run on your stretched R's?
    London, Ontario, Canada
    1,059
    Stretching it shouldn't change the gearing, you should still run the same as your stock arm unless you've "added" power somehow. I'm running a +2 and I was running 14-39 with 18" tires. When I put the 21" paddles on I couldn't pull top gear at Silver Lake so I dropped the front sprocket back to a 13. I gave up some overall speed with the 18"s on but we mainly ride woods (like Rose City) and the slow crawling ability was improved.
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
    STL
    3,560
    see I just dont know. I want to be able to hit the trails and ride everywhere! Really want to play on some hill climb stuff too. I want to be able to drag race it at TF11 too. I guess I will be giong with 14/39. Thats stock right?
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    13/39 stock..
    STL
    3,560
    ya Im sure I would know what stock is if I would just open my freaking manual. Thanks for the input guys
    May 2007
    Coshocton, Ohio
    1,815
    Are you going to be running stock tires? If you run shorter tires, that will change the over all gearing too. Something else to think about.
    Appalachian American Racing
    the home of
    STL
    3,560
    no im looking at running some 18" fast trekkers, so more than likely looking at a 14 rear sprocket and buying a 13 tooth and 14 tooth front sproket just to play around and see what fits best for me.
