i tore the bottom end of my 85 200x apart, now i have it back together but it seems to jammed in neutral and it wont move at all. Any ideas? Thanks
1985 70
1985 200x
1985 200x hot shot
1985 200x part trike
1983 185s
1993 fourtrax "whoretrax" everyones had a ride
1967 suzuki hustler 250 2 stroke
2004 buell blast 500
I am putting my 83 200x back together tonight. is your shift drum binding? can you turn the drum? the shift forks also have a R and a L on them, have to go in a certain way, and the other thing I noticed was 1st gear. you can install it backwards, all the other ones you cant really screw up, but that one you can and it will bind on the kick starter idle gear if put in backwards. (p. 8-10 of the manual)
