Results 1 to 9 of 9
Thread: What is the difference between the 85'&86' Tri-Z front e
    Northern CA
    1,104
    Could someone please let me know what the difference is. Everyone Ive talked to around here says there is one but could not tell me exactly what it was. Any info would be great
    Thanks
    85' Tri-Z 250
    85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    87 Ninja750 3wheeler
    Northern CA
    1,104
    it should have read "what is the difference between the 85 & 86 Tri-Z 250 front end"
    Thanks
    85' Tri-Z 250
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    Apr 2003
    Bay Area CA.
    2,638
    hey man where in northern cali are you?
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Northern CA
    1,104
    Marysville!! About an hr. above Sac. Where are you
    85' Tri-Z 250
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    asc180's Avatar
    asc180 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Howard City, MI
    209
    the difference is the fork tube diameter. the 86 has bigger tubes which make the triple clamps different too. the triple clamps will interchange though.
    davham's Avatar
    davham is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    211
    The above is correct. All you need is the triple clamp and both forks, everything else will bolt right on. I think but not sure, the '86 will have slightly more travel. I have an '85 triple clamp and left fork, the right fork has a bent upper tube. You can have them cheap if you want them.
    Dave
    Northern CA
    1,104
    Thanks everyone!!!! I understand now. Thanks for the offer Dave I will keep you in mind if the one I have lined up doesnt pan out. Very nice bike by the way. I hope mine will look as good as that one. I have one that is runing now that I would like to restore, I am just torn between working on the one that is running excellent but looking shabby or starting on the Frame on the new one. tuff choices!!! Again, thanks to everyone who has helped me this far!!!
    Craig :-D :!: :!:
    85' Tri-Z 250
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    davham's Avatar
    Jul 2003
    211
    Your starting with just a frame? Thats quite a project. You might try placing an add on here, i think YTZ250#1 has some Z parts along with several others on here and then there's ebay. IMO, since you have one to ride I would start with the frame. Almost everything is still available new but the plastic, if it's yellow you can only get the rear fenders($99.95). I got quite a bit of stuff from partsfish.com
    and try to find a real yamaha service manual
    Dave
    Northern CA
    1,104
    yes starting with just a frame. I just purchased the 86' front end, Brakes, Powder coated Yellow Hubs, Swingarm w/shock linkage. Do you know of anyone that will extend the Swingarm +6?? This is the first bike that I will have actually built from the ground up. Should be interesting but I do have a complete bike to go by in case I get in trouble. Ha!! Nice winter Project. I live close to Grass Valley CA and have a "Friend" that works at the Miers MFG. They still make the front and rear plastics. White, Yellow and Black I think. Stay in touch and I will try to keep informed on my progress.
    Craig
    85' Tri-Z 250
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
