90/110 rear bearing carrier. might be kind of strainge question, but I was doing some very deep stream crossings two days ago with my 1978 90, and got to thinking, would there be any advantage to having a drain hole drilled in the aluminum rear axle bearing carrier on the bottom? That water must just sit there between the bearings, weeping past the inner seals. I just installed new bearings with seals on both sides of the bearings
