what is the best source for the snap ring that goes near the disc brake assembly on the axle where the locknut is for the axle....also anyone have the diameter of the snap ring??.....Thanks Paul
86 350X
86 200X (son's)
86 250sx (daughter's)
84 70/125lifan
68 SS Chevelle
72 4X4 Chevy Truck
Click to see what I do
Do you mean the snap ring that holds the axle carrier in the swing arm or the circlip the locknut pushes against to hold it all together?
The manual calls it a snap ring but it is the circlip that the locknut pushes against that I am looking for.....Thanks
86 350X
86 200X (son's)
84 70/125lifan
68 SS Chevelle
72 4X4 Chevy Truck
That's a common part - used on a lot of newer Honda quads - #20 on the "rear wheel axle" fiche. Still available new.
The tricky part is the "axle nut washer" #19 on the fiche. Not used on newer quads and not available new.
I'm going to use a whole 400ex axle nut and clip on my 350x since I had to cut it all off to get the axle out. What a pain...
thanks....off to the dealer I go....
86 350X
86 200X (son's)
84 70/125lifan
68 SS Chevelle
72 4X4 Chevy Truck
i got one ill send you.. whats your address?
Rides
85 ATC350X
85 ATC200X
Thanks Eric....PM sent
86 350X
86 200X (son's)
84 70/125lifan
68 SS Chevelle
72 4X4 Chevy Truck
