does anyone know if a front end off a 185 will fit a 1982 110?
does anyone one also know if there is racks and add ons for the 1982 110?
any help would be great
jake
jake
I don't know for sure if the front ends will swap, but you could check the bearing sizes on a parts finder and see if they are the same I.D. If that mates up then you are on the right track, just have to measure the height of the stem and neck on both bikes and see if they are the same height... if that all looks good then I would try the swap. But like I said, I don't know for sure and hopefully someone comes along with a more concrete answer for you.
i'm planning on doing a swap myself. a 185s fork to my 85 125, basicly the same frame as 110. now from asking and searching around, to my understanding the only thing i should need to do is move the fork stops (cut/weld) other than that it should be a basic bolt on swap. someone please correct me if i'm wrong here.
Yes very similar to the 200x front to a 250sx swap
Machines owned:
85' atc250r (sold)
85' 250sx- the daily rider
85' 250sx- building w/ fourtrax 300 engine
83' Alt125- the Beast
85' atc70
83' atc70
01' yamaha wolverine 350 yz blue(only bike i ever bought new)
SILLY RIDER! TRX IS FOR KIDS!!!
i rather not cut and weld.
I did the suspended 185/200S forks on both my 90's. They do bolt on, but you will need to remove the steering stops from the frame and weld on some new ones. not a huge deal but necessary.
2) 1977 Honda ATC90
2)1985 Tecate
2005 Banshee LE
01 Honda 300EX
74 Suzuki TC100
66 Honda 305 Scrambler
