Results 1 to 15 of 18
Thread: 1985 Honda Big Red vs 1987 Big Red
    May 2011
    West Tn
    I recently purchased my 1985 Big Red. A friend of mine has a 1987 Big Red that is stock just like mine. His 1987 will run off and leave mine even when I have a head start. Could someone please tell me what the deal is. Did they change something in the gears or rear end during these years? It just seems like my 1985 is geared so much lower that the 1987. Could someone with a a little 3 wheeler knowledge help me with this. Thanks in advance.
    bucko is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2011
    Marion,Ohio
    255
    Do you guys have a big weight difference between you?What size tire's are you guys using?I don't think they changed any gearing.
    dream3wheeler is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2010
    International Falls MN
    362
    Before i sold mine i ended up asking a lot of questions about my 85 big red. And according to some people on 3wheelerworld and others on youtube..... there were some changes in gearing. And if im not mistaken there could have been some slight changes in the design also. If you think about it they would'nt put out the exact same thing every year, im sure they changed them up a bit
    Lauderdale County, Alabama
    2,029
    I now the shaft changed a bit over the years, and all the decals, but I didn't think anything that would be that extreme.
    Is your BR old and tired?
    Plattsburgh, NY
    2,311
    I would say it's either weight difference or tire size or a tired motor. U should compression test both of them.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    franklin,, Ohio
    181
    Yes i agree their are a lot of variables to this.. Tire size, weight, engine compression, rider ability, traction, engine jetting, etc... Big reds from 85-88 had the same transmission and final drive ratios. 1986 and newer Big Reds had i slightly different two piece swingarm design and incorporated a sealed internal brake drum, 85's had a solid one piece swingarm and a external brake drum(which was a poor design). I dont know the weight difference between the two different rearends but it shouldnt be enough to make a noticable difference in the overall weight of both machines. If both are completely stock and are running good, factory tuned, stock tires/tread life, they should be equally fast.
    If your friends 87' is faster than yours, i would run a compression test and inspect your sparkplug to see how its burning.. This will tell you if your jetting is right.. Even if your just slightly running rich it can have a big difference in the power of your engine....
    Machines owned:
    85' atc250r (sold)
    85' 250sx- the daily rider
    85' 250sx- building w/ fourtrax 300 engine
    83' Alt125- the Beast
    85' atc70
    83' atc70
    01' yamaha wolverine 350 yz blue(only bike i ever bought new)
    SILLY RIDER! TRX IS FOR KIDS!!!
    Saskatchetoon Sk
    360
    Not to mention the one way clutch....
    If you have 1/4 of the friction left and he has 3/4 it would make a big difference
    1982 Honda ATC 200
    1984 Yamaha 225DX
    May 2011
    West Tn
    Thanks guys for all the info. I rode the 87 model and it was not geared nearly as low as mine. My 85 model will only run about 35 mph. What should be the top end speed?
    Dec 2007
    Quebec,Canada
    1,014
    35 mph??
    I think it's a little bit low....the 250sx can go 55mph. 20 mph slower.....not sure.....
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Michigan
    1,144
    My 85 BR will do around 50 mph. All stock
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Saskatchetoon Sk
    360
    something seriously wrong with only 35 mph....
    1982 Honda ATC 200
    1984 Yamaha 225DX
    Dec 2010
    845
    The guy I bought my 86 big red said that there was a gear reduction in 85 Im not sure if that's true but I think they put it back up in 86-88
    R-tifacts's Avatar
    R-tifacts is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    New York
    404
    I have an 85 BR and my buddie has an 87 they are neck and neck when riding, no noticeable diffrence when riding however we have noticed some light changes to the starter housing and side case from one to the other not sure why but they are a little diffrent.
    Dying breed with a need for speed
    85 ATC 70
    85 250es Big Red
    85 ATC 250R
    86 ATC 350x
    86 KXT Tecate
    87 ATC 250r replica
    NEPA
    7,051
    ^^^ Long shaft starter^^^^ : )
    R-tifacts's Avatar
    New York
    404
    long shaft starter, did not know that thanks atc007, any idea why they changed it? i have never heard of any problems with the "short shaft" starter.
    85 ATC 70
    85 250es Big Red
    85 ATC 250R
    86 ATC 350x
    86 KXT Tecate
    87 ATC 250r replica
