Thread: tuning help 81 250r
    Deathrocket's Avatar
    Deathrocket is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Assachusetts!
    349
    tuning help 81 250r
    ok folks, I put a new 38mm round slide keihin and a DG head pipe on my 250r. the carb came with a 135 main jet, since the bigger oval slide carb it replaced had a 145 jet i figured i would swap to that to start with and see what happens on start up, from cold it kicked over on the first kick and wouldn't idle well. and wouldn't rev up much at all unless I feathered the throttle and still wont get to top revs. checked the plug and its wet, so I went back to the 135 jet. now to get it to idle well the idle mixture screw is turned all the way in and it will rev up to half throttle well but any higher than that then it bogs out and dies, and the plug is still wet. do I need to go down some more jets? or what? or what should I do? what needs adjusting?
    Assachusetts!
    349
    anyone? anyone?
    Apr 2008
    NW, IND.
    842
    Have you tried raising the needle?
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    O.C., Oregon
    921
    Could be too much carb for that bike, adjust the needle clip and see what happends then go down a jet size if nothin happeneds...
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Rollingmenace is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2008
    Colorado
    224
    I would say your deffinitly gona have jetting issues on the top once properly jetted the carb will perform well but it will have horrible low end and throttle response... I see people running 38's on air cooled bikes but most usually there big bores or have some serious motor work on a piped stock or close motor 34mm is most adequate... As far as jetting advice start your air scew 1 1/2 turns out around a 40-45 pilot work on idle and then focus on getting main jet close...
    82 ATC 250R (AS $ Crusher.. Project 450 swinger)
    84 ATC 200X (Project Blackout) Hers
    86 ATC 250R
    86 TRX 250R (The Golfcart)
    87 CBR 1000F SSSA STREET FIGHTER
    95 NINJA 250EX
    My Feedback http://www.3wheelerworld.com/showthr...-Rollingmenace
    O.C., Oregon
    921
    That exactly what i was thinking! It probably run once you get on the top end but it'll have trouble gettin there
    2017 YZ 250x- Braap
