Can someone tell me what intake manifold do you use- the 185s or the 200x intake?
(so that the carb clears the 200x frame in other words)
Previously Owned:
1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
1981 ATC 185S
1984 ATC 250R
1981 ATC 250R
1983 ATC 110
1969 HONDA MINI TRAIL 50
TRIKELESS
You need a 200x intake to do the swap . If you need one give me a call.
Thanks Mike, glad you responded ,- can I trade you back the 185s manifold one I got from you for the 200x one? I didnt know about the clearance issue.![]()
Previously Owned:
1981 ATC 185S
1984 ATC 250R
1981 ATC 250R
1983 ATC 110
TRIKELESS
Thanks man..........
Previously Owned:
1981 ATC 185S
1984 ATC 250R
1981 ATC 250R
1983 ATC 110
TRIKELESS
