Results 1 to 9 of 9
Thread: What material are Honda ATC fenders and headlight assemblies made of?
    Scootertrash's Avatar
    In the sticks
    4,638
    HDPE? PVC? some type of nylon?
    Crest California
    3,014
    I'd guess a form of polyurethane..
    LED obsessed
    2015 Yamaha FJ-09
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    Why do you need to know?
    Here is what Maier uses...
    "...a proprietary thermoplastic olefinic elastomer (TPO), specifically designed for our applications. This high-impact polypropylene alloy delivers a high-gloss finish with strength characteristics capable of enduring extreme weather and temperature conditions. Maier plastics are UV-stablized, resistent to chemicals and avaliable in a wide array of colors and films."
    Polypropylene is what milk jugs are made out of.
    Dec 2005
    Wisconsin
    1,141
    Plastic...... lol
    High Density Polyethylene is what Milk Jugs are made of.
    If you notice Milk jugs do not have that shine a set of fenders will have, the Polypropylene is a harder plastic that has the characteristics of being able to give that shine a new set of fenders has.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Baltimore, MD
    6,088
    Some headlight assemblies are metal. Some fenders were fiberglass. Early plastic Honda fenders were made from a very hard plastic and later fenders were made from a softer, or more flexible plastic. Materials seemed to vary as the technologies improved.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    In the sticks
    4,638
    The reason I'm asking is because I'm going to need a black 350X headlight set up for my 85 200 AutoX project. I've seen threads here on different ways to color the plastics, from paint to dyeing to that aussie guy who made the black headlight housings for the 350X, but it doesn't appear he's been around in awhile so I'm guessing that those aren't available anymore. Knowing the proper material may give me the proper info to effectively color the 350X headlight housing I have without ruining it. I have a couple of old broken 200S headlight housings I could practice the dye method on and they also have automotive spray type dyes. Has anyone tried those out at all?
    WIkid500: HDPE is available with a high gloss, I've used it to replace factory belly pans on sleds at a fraction of the cost of an OEM plastic belly pan. It's also used for truck bed liners. Both HDPE and Polypropylene are polyolefin derivitives, so they are somewhat similar materials.
    I'll post a thread on the 200 AutoX build as soon as I get all the parts together and get started.
    JustEnough's Avatar
    Oct 2009
    Elk Grove, CA
    334
    Oops on the milk jug plastic comment.
    Here is a cheap possibility for a black headlight shell:
    BLACK UNIVERSAL HEADLIGHT
    In the sticks
    4,638
    Quote Originally Posted by JustEnough View Post
    Thanks for the link, but I'm gonna run a 350X headlight assembly. I will use paint as a last ditch option. I've been reading up on how to dye plastic and I've got some fender and headlight scraps around here I could practice on.
    O.C., Oregon
    921
    Let us know how the dyeing process works!! I'm interested in doing this myself, if it's possible..
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
