Results 1 to 15 of 23
Thread: Whats the EASIEST way to fix a stripped oil drain plug
    250Eddie's Avatar
    250Eddie is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Miami,FL
    395
    Ok so i was attempting on doing an oil change on my sisters 87 250sx and i come to find out that the guy that had it last had stripped where the plug goes and he tryed to put a diff plug w/o tapping it the right way and he screwed it up, so now the plug i have that was on the bike dont fit it and a friend of mine told me to use a rubber plug, so i dont know if that will work right or not.
    Any help will be awesome.
    87-250sx
    86-300es Big Red,The Beast
    85-250sx Tiny SwampThing
    85-250es Big Red
    84-70 ( My Sons Bike )
    Scootertrash's Avatar
    In the sticks
    4,638
    I wouldn't use a rubber plug. The easiest and cheapest thread fix is a heli-coil. The Timesert is another fix that, from what I've read, is better than a helicoil but I've never used one(yet). Timeserts are a bit more expensive than a helicoil kit. The last resort would be redrill and tap for a completely diferent size drain plug, but only if the threads are so messed up they are not repairable.
    Helicoil kits are available at NAPA and the like, usually around 40 bucks. Timesert kits run about 100 bucks. Maybe you can find a member in your area who will help you fix your threads?
    May 2008
    Northwestern Ontario, Canada
    552
    My 250r has a stripped plug as well. Helicoil is the way to go, but in the mean time you can put teflon tape around the bolt threads and it should hold for a bit just don't tighten it too hard...of course that depends how bad the threads are in the first place.
    Never seen a "timeserts" kit, might have to check into that...
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Plattsburgh, NY
    2,311
    Easiest is NOT the best. Question should be how much does the trike mean to u or how much do u like doing rebuilds.
    Come on keep these things alive, do it right. Also think of re-sale value and what someone might think if u were to ever sell it. I know if I was buying a trike, quad, go cart, dirt bike or whatever, if I look at the bottom of the motor and c a rubber plug..... Uhhh yeah red flag goes up and I wonder what else is hacked cobbed or half assed. Cuz if u can do that there, then the smaller issues will definitely not be taken care of correctly.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    In the sticks
    4,638
    Quote Originally Posted by Taiser View Post
    The bad thing about teflon tape is that if the htreads are bad enough the plug could vibrate out and then you have REAL problems.
    Tattool23 is right: Do it right the first time!!
    Jun 2009
    Leander TX
    2,217
    Check auto parts stores for oversize drain plugs. I've used them before. Not the best way but fairly easy and better than a rubber plug.
    Nov 2006
    Huffman TX
    891
    mines stripped also... i just rap like half a thing of teflon tape on there and shes good to go everytime i buy new oil i gota buy a roll of telfon tape
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    Connecticut
    1,605
    The oversize drain plugs will cut new threads into the drain plug hole as you screw it in the first time. That would be the easiest least rigged way to fix your sister's ATC
    Although a timesert is a more self locking insert, I've never had an issue with helicoils and I've used them in numerous drain plugs. If you have to buy a kit anyway, there may not be any more than 20$ in price difference to get a timesert kit. Plan on spending 50-70$ to repair this and a new plug. If you don't fix it right, you could have bigger issues down the line.
    Put grease on the drill/tap and tools and keep cleaning them off, then I'd flush with a little diesel to be sure it was clear.
    Plattsburgh, NY
    2,311
    i have 4 more Time-Sert inserts. they r 12mm by 1.5 thread pitch. i think the drain plugs r the same on the '80's honda trikes. i could be wrong though. i would be willing to sell an insert and the use of the kit for the install for $30 then $5 to ship it. when u finish the install just ship back the kit to me. then its fixed properly and its less then buying the $100 kit i bought and less then a heli-coil.
    just an option, throwing it out there to help out.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    bobotech is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    spokane, wa
    363
    Why is it a bad thing just to drill out the hole to the next bigger size and tap it with bigger threads for a bigger drain plug? That seems to be the easiest way. Drill out the bad, cut new threads with tap, and put new larger plug in place and call it good.
    MonkOFox's Avatar
    MonkOFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    texas
    264
    Yep, just tap a bigger screw hole that will fit a 2 liter bottle
    screw top. Then you'll have the hole plugged and can use twice as much oil!
    1985 200S - fixer upper
    Aug 2004
    Phoenix
    1,226
    Quote Originally Posted by bobotech View Post
    Its not bad, but in the end you still have a steel bolt going into aluminum threads which after time are prone to wear out depending on how much use and torque is on the bolt. The hole that you drill for the timesert insert is smaller than that of a helicoil which keeps more metal for strength in the case. Timesert is a FULL steel sleeve that has a countersunk lip and tappered end threads which locks it in place making it impossible for it to work its way into the bottom end which helicoils are known to do. I used helicoils for years but after using timesert its a superior product, no question. Its a permanet repair that you will never have to mess with again, and in the end be better than new.
    4 Strokes are NOT the wave of the future!
    In the sticks
    4,638
    For me it's like this: How many times can you drill it to the next size? A proper fix on the original hole will give you the option drill it out later-if needed. I never do more than I have to to do a PROPER repair, you may need the options later.
    Well what would you like, 9/16ths, 5/8ths?? 14MM? usually when you get that big, it's a coarse thread. There all steel on aluminum, but repaired, they a fine pitch for such a large sized thread. Not many people have taps laying around or the bolts to match....... Your suggestion ranks up there with a self tapping or rubber plug.
