Results 1 to 2 of 2
Thread: Ytm 175 clutch issues
    Jun 2011
    Ohio
    I got a ytm 175 and the clutch doesnt grab very well the plates have plenty of meat on em but im not sure if the pressure is torqued in or not im pretty sure it isnt cuz I took it out very,easily I got it like this so what is the correct torque setting cuz I think that could be the reason it doesnt grab like it should
    Wichita, Kansas
    1,361
    Sounds like you need to adjust them. If you take the side cover off the right side - 6 10mm bolts, you can adjust them.
    There is 2 jam nuts and a slot for a screw driver in the middle. Loosen those, turn the screw driver slot until they just start to drag, then tighten the nuts while holding the screw driver in place. They should barely drag.
    If that doesn't take care of it, let us know, might be something missing/assembled wrong in the clutches.
