Its bored out to 285 . He wants $ 1500. Which in Canada is good I believe. But the trike is 7 hrs away. What do you guys think. From pics it obvisouly has a oil leak.
thats a nice looking tecate for $1500 in Canada. i know i guy who bought one of theses for $1200 and it didn't even run! as long as the motor sounds tight the oil leak shouldn't much just a new gasket. if you go look at it check around the case bolt they my have been over torqued and cracked the case that may be causing the leak
Sounds and looks reasonable.
LED obsessed
2015 Yamaha FJ-09
That's got front disk brakes, is that OEM or has someone put them on it?
84 had drum front. the rest were disc.
2) 1977 Honda ATC90
2)1985 Tecate
2005 Banshee LE
01 Honda 300EX
74 Suzuki TC100
66 Honda 305 Scrambler
If you can afford it, want it, and have trouble finding them, go for it!
I had a leak on my Tecate like that . I rode 2 hours double up when my friend broke his arm (Before cell phones)the chain was so tight it roached the counter shaft.
Hey where abouts in bc do you live I'm on Vancouver island and where is this tecate I'm not interested just wondering
Trike is at Cambell River. I live in Vernon. If it was closer it would be in my shop right now, aslong as it is as good as the guy says it is . I dont want to to use up all that time travelling just in case I decide against it. So please buy it , it is making me nuts (lol)
Bored out to a 285? Wow....
FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
86 250R
86 350X
87 250sx
85 200x/cb350 custom
81 185s/200x/250r custom
79 atc 70
Mini-Trail z50, 110cc Pit Bike
and many multi-wheeled machines
Ya its 2hrs away from me but I don't really like the 84 tecate ya they never show up this close to me but I love the 85-87 though but they cost a fortune Here in canada
This is the first Tecate I have come across. I dont know much about them. What makes the 85-87 better than the 84
The 85 has aluminum wheels, front disc brakes, a brace in the footpeg, 2mm larger carb, grease zerks on the dogbone, adjustable rear shock, seperate light and kill switches, 4/156 rear hub spacing (84 was 4/4, 85 won't fit inside an 8" wheel), there are also some small frame differences. The 85 was longer and lighter. The seam on the inside of the frame where the footpeg mounts is fully welded on an 85, spot welded on an 84. The rear carriers are different where the rear caliper mounts.
Rides:
1982 ATC70 (Lifan manual 125)
1987 LT80 (piped, widened)
My feedback thread
RIP Trace.. Godspeed.
80' Honda CR80R
78' Honda XR75
77' Honda CT-70
74' Honda CT-70
75' Yamaha GT80 Enduro
76' Kawasaki KZ900
73' Kawasaki H1-500
76' Kawasaki H1-500
Yeah I was wondering about that. Makes me a little nervous its been bored out to that size. However maybe the guy does not know for sure . He kept calling it a KX trike and did not know it was a Tecate
