Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Thread: my wheeler doesnt run any ideas?
    jr315rn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2011
    rochester ny
    288
    i have a 1982 honda 110 , has compression, im lost on whats wrong with the old girl any help would be great
    jake
    Oct 2007
    Minneapolis mn
    4,067
    Do you have fuel?... Do you have spark?...
    May 2011
    rochester ny
    288
    plug is wet, spark is good
    Oct 2007
    Minneapolis mn
    4,067
    Starting with the wet plug, not good. When was the last time it ran? Air filter clean? (no rats nest in the airbox) Carb need to be cleaned?
    Jun 2011
    arkansas
    9
    you need three things to make an engine run: Fuel/spark/air. pull the plug and replace or you can try to just let it dry out. with the plug out turn the engine over a time or two. check air filter. put in new plug and start it up.
    Aug 2010
    St Paul, MN
    88
    You say it has spark, but is it sparking at the right time? If you've monkeyed around with your pulse generator at all, maybe you put it back in 180* out of time. Its also possible that your timing chain skipped a couple teeth and its too far off time to run now. Get a manual and read how to check the timing. Hope you get it figured out!
    1987 Honda 250es
    1987 Honda 250sx
    1986 Honda 250es
    1985 Honda 110
    NEPA
    7,049
    Put a new spark plug in it. Make sure it's the right one they are shortys,not long. If you haven't ran it for awhile,lay it on it's side. this puts some fresh fuel into the carb,while the old is flushed out the overflows. Fresh fuel,NEW spark plug,it will prolly sit there purring.
    May 2008
    Northwestern Ontario, Canada
    552
    Bad air filter (clogged), bad plug (might spark but not under compression), bad timing (unlikely), gummed up carb, old crappy fuel. Start with the easiest, new fuel, new plug, clean the filter. Dump the old gas, put in fresh fuel. If that don't get it going, get a compression test done, then you're into the electrical, might be a weak spark etc.
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    May 2011
    rochester ny
    288
    it was running great now it doesnt run at all?
    Nov 2009
    N Hollywood/ CA
    588
    jr,
    80 percent of all problems I have when I pick up an old basket case is the Carb. Another thing to take in consideration, do not overkill your pull cord as your pulling it many times it might rip. nice & easy.
    May 2011
    rochester ny
    288
    i just dont know what to do im only 16 lol dont have all the know how like u guys
    Oct 2007
    Minneapolis mn
    4,067
    Start with downloading the manual, and grab a coke... Start reading!
    May 2011
    rochester ny
    288
    where can i get said manual?
    Nov 2006
    Huffman TX
    891
    Quote Originally Posted by Thorpe View Post
    nicley said!! Im 16 also dude!! wont take you long to beable to have that thing apart and put back togeather faster then you can say done!! untill then manual and alot of mess ups is what it takes
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    May 2011
    rochester ny
    288
    heres the thing guys i got the wheeler for 200 and put another 200 in to it trying to get it fixed , i just want to ride and cant take it anymore
