Page 6 of 6 FirstFirst ... 4 5 6
Results 76 to 80 of 80
Thread: 86 Tecate build thread
  1. #76
    R-tifacts's Avatar
    R-tifacts is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    New York
    404
    Got the govonor lever from ezmoney, thanks man! gonna get it together and dial in the carb. Had a small set back with the shock hose, it was seeping fluid very slowly so I had to tear it back appart. Lost my nitrogen charge and having trouble finding another hose the correct length. I ordered a stanless steel brake hose by length, it uses the same 10mm banjo fittings so I am hoping that will work, im just not sure about the inside diameter of the hoses.....we will see. Hope to have some pictures of her in action soon!
    Dying breed with a need for speed
    85 ATC 70
    85 250es Big Red
    85 ATC 250R
    86 ATC 350x
    86 KXT Tecate
    87 ATC 250r replica
  2. #77
    Mar 2003
    NJ
    911
    this fella seems to have a new hose...posts 4 and 12. ill see if i can find out what he used.
    http://www.3wheeler.org/vb/showthrea...ing-a-facelift
    No response... Sorry...
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
  3. #78
    R-tifacts's Avatar
    New York
    404
    Just bolted the last part (front sprocket cover) on the Tecate over the weekend, She's done! and paciently waiting for the ice this winter.....Click image for larger version.
    I have some random extra parts I had duplicates of or didnt use. Rather than sit on them forever I would like to send them to a good home. If anyone needs anything pictured below let me know and I will get a shipping quote. Im not trying to make any money so If your willing to pay shiping I will send you the part/s. This being said I do ask that you need the part for your bike. I will not send anything to someone so they can turn around and sell it on ebay. Also I am not intersted in shiping international, sorry. I am just trying to help out some fellow Tecate owners.
ID:	132774 oe headlight shell - was cracked and fixed but is useable
ID:	132775 oe Pipe - has small dents but useable for sure
ID:	132776 Homemade coolant tank cover - if you have a coolant tank that was repaired but looks nasty this looks and fits pretty good.
ID:	132777 Jug - has power valves in it bore could go either way your call on hone or sleve, coolant bleeder is broke off in water outlet.
ID:	132778 Brake rotor - has some piting, coolant tank cap, gas tank mount, chain roller and slides, caliper bracket, grips for twist throtle, reeds cage and intake -dont know if leaks or not, swing arm bearings(no end caps), Some kind of water pump adaptor or turbulator maybe?
    85 ATC 70
    85 250es Big Red
    85 ATC 250R
    86 ATC 350x
    86 KXT Tecate
    87 ATC 250r replica
  4. #79
    bigredridr's Avatar
    bigredridr is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    shoharie NY
    273
    a 250R and a tecate in your living room...... huh looks like you could fit a Tri-Z in the middle..............do i see another build?
    85 1/2 Tri-Z
    85 350X
    85 250ES
  5. #80
    N/A
    5,818
    I dont know what i like more, these oem restores sure like nice! please put them in a glass sealed box so you dont gotta dust them lol!
