Results 1 to 15 of 15
Thread: my dang 250sx
    Escanabajosh's Avatar
    Escanabajosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    U.P. (upper michigan)
    352
    my dang 250sx
    guys my sx is giving me crap and I can use some advice.
    When I hit the gas it chugs and dies...was working great all day yesterday at camp but today 5 min down the road it starts to chug.
    air box is good with fresh filter
    only thing I can think of is carb is dirty. should it be rebuilt or just shot with some carb cleaner first?
    I cleaned the petcock last fall but I'll check that out also.
    tried going with the gas cap off the bike but it still did it.
    anything i missed or worth trying?
    I also cleaned up the plug
    Oct 2009
    352
    sad thing is i got towed home by the old lady on her polaris quad!
    Oct 2009
    352
    one more thing.......it happen last fall one time also right after I tipped the machine over, didn't roll just tipped.
    The tank is good but i wonder if junk inside shook up from the impact?
    Whats that stuff used to coat the inside of the tank? I think I'll get the carb rebuilt and coat the tank.
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    Clean everything you can before buying rebuild kits and stuff. It can be really stupid and easy fixing but can also be more complex. Start with the obvious. You're on the right track with cleaning the carb, petcook, tank though.
    I'm not sure what you mean with "chug".
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Oct 2009
    352
    thanks
    the chug is when i push on thumb lever it starts to starve for air/gas it sounds like, the rpm slows and at full gas it dies. It will run at idle and can rev a little in N but when in gear it will idle but as soon as gas is hit it "chugs",lol hope that helps
    NEPA
    7,051
    Clean your carb. To be perfect and avoid it all again. Also clean your tank,and petcock. Put in a NEW spark plug. Drain and flush your engine and rear oils. Clean and oil your air filter,and enjoy for a LONG time.
    Oct 2007
    Minneapolis mn
    4,067
    Agree 100% with your carb idea...
    Oct 2009
    352
    Thanks guys I'll get on it and report back what happens.
    might not be right away but I'm ticked she towed me home so I gotta fix it,lol
    250Eddie's Avatar
    250Eddie is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Miami,FL
    395
    Yea i would buy a full carb kit, use alot of carb cleaner to clean out all the holes and passes where the gas goes thru and put the new jets also the needle make sure u put the needle on the groove it needs, should be the second groove from the top.
    87-250sx
    86-300es Big Red,The Beast
    85-250sx Tiny SwampThing
    85-250es Big Red
    84-70 ( My Sons Bike )
    Oct 2007
    Minneapolis mn
    4,067
    And DONT buy a "moose" kit... They suck.
    250Eddie's Avatar
    Miami,FL
    395
    nah stay with the shindy kits there the best in my eyes ive never had a problem with any of them.
    87-250sx
    85-250es Big Red
    Nov 2010
    Warwick, RI
    66
    Quote Originally Posted by Escanabajosh View Post
    KBS Tank Coating Kit. It comes with a degreaser, an acid wash, and the liner. Very easy to do.
    May 2009
    Nova Scotia, Canada
    61
    Check that your choke needle is seating properly. My 85 BR was working fine but died when I would give it gas. We cleaned the carb, tried it and it did the same thing, so we changed the carb and it still did the same thing. Finally we tried the original carb again but changed the choke to a 86 style jet and it cured the problem. It would rev up perfectly. Maybe just as simple as that.
    86 atc250r
    86 250es
    86 tri z
    86 trx250r
    86 trx250r
    08 trx450r
    08 banshee
    08 gt mustang
    Oct 2009
    352
    Thanks a bunch guys.
    I took the carb off today and she was dirty,lol! bunch of rust mud stuck in the bowl.
    Looks like i'm gunna have to get new gaskets or a rebuild kit cause they are junk also.
    havent taken the peatcock off yet but i'm sure it's dirty in there also.
    I'm gunna clean her up and get a cheap in-line filter till I can afford the tank coat kit.
    Thanks again
    May 2008
    Northwestern Ontario, Canada
    552
    Throw some "seafoam" in the tank after you put it all together, it will clean everything that you might have missed. That stuff works miracles!!!
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
