Results 1 to 9 of 9
Thread: can somebody positivly identify this 110 piston
    Jan 2011
    Brazil, Indiana
    2,087
    I know it is an over bore piston just dont know what brand. Honda rings are too thick to fit in the groves. Need a little help from the 110 gurus.
    Attached Thumbnails Attached Thumbnails 110 piston 004.jpg   110 piston 002.jpg   110 piston 001.jpg
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Visalia, CA
    720
    Holy Big dome Batman! Is it a 61mm piston or 58?
    "Your 4 wheeler must be fast because you were haulin' ass....UNTIL I passed you on 3 wheels"
    RIDE RED......OR RIDE HOME
    TRIKES ARE NOT DANGEROUS......IDIOTS ARE!
    RIP
    NOS_350X is the most bad-ass person in the world
    6,798
    First look and see if its a 14mm or 15mm wrist pin to determine if its a atc 110 or a atc 90 piston . Looks like a Rocky 54 or 55mm to me . JCC was the piston maker but Rocky was most likely the distribator. I prob have rings for it just LMK what size it is .
    Jan 2011
    Brazil, Indiana
    2,087
    Thanks shortline, It is a 15mm wrist pin. The piston measures 54.60mm diameter.
    First ring grove measures 1.27 mm
    Second ring groove measures 1.23 mm
    Oil groove measures 2.50 mm
    I need rings for it. I broke the oil ring when I was taking it off to clean it. the piston is marked 5 on the top assuming it is bored .050 over. Shoot me a PM with the price you need for a set of rings. Id like to have this going for Trikefest. What do you think the compression ratio is on this unit?
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    6,798
    Did you take that 54.6 measurement at the skirt or at the ring groves ? Sounds like its a 55mm to me . I have a NOS set of 56mm rings that you could file down but let me check on the ring thickness for you . Those 1 piece oil rings are tricky to replace with out breaking them .
    Quote Originally Posted by hoosierlogger View Post
    Jan 2011
    Brazil, Indiana
    2,087
    I measured it at both ends and neither end measured 55 mm. Ill see if I can get the bore measurement.
    Yup thats when the oil ring broke when I was taking the damn thing off should it come off the top or the bottom?
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    6,798
    Oil ring comes off the top of the piston and you have to work it off dont try and spread it all at once or it will break . I have a few tricks for installing these but its hard to explain LOL .
    Jan 2011
    Brazil, Indiana
    2,087
    That is exactly what I did. I tried to take it all off at once. I almost had it too, it came off real easy after I broke it in half. LOL I am interested in the rings if you find any that will work.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    6,798
    I believe the compression rings I have are to thick both measuring @ 1.25mm but the oil ring looks fine . I have a few of those pistons as well and the oil ring seems to fit in all of them . If your 2 top rings are good you could use my oil ring to get you up and going . 20.00 shipped for the NOS rocky ring set if you want it .
