My 200 S historically would be a hard start and then run rough at times. after extensive cleanig of the carb, adjusting the needle etc, i detemined it was the stator (no the lite stator but the ignition stator was faulty. Does the trike idle good then die down once throttle is pressed? The wiring is a pain in the ass because it could be in the harness. Just to be safe check all the visual wires you can see,check and dieelectric grease all the connections of the electric, do a ohms check on the wires coming out of the stator cover. Im not sure what the ohms reading will be but it is on the web somewhere, if that fails then check the ignition coil as well. It sounds more like a fuel type problem however. Double make sure that the needle in the carb are cleaned out with compressed air. I have had a little tiny piece of shmegma in the needle jet in the past which caused the same type of problem. Go thorugh that fuel systme first, kinked hose, blockage at the petcock coming from the tank, etc before you rip the stator apart. Hopefully this helped and you can go back riding asap!
trikes are the best
Honda 250 es big red, Kawasaki KLT 200, Yamaha YTZ 250,honda 250 Mini skidder, Polaris 400 scrambler, honda 200 TRX, polaris 583 rotax sled and more to come hopefully!
