Mine is thin and orange. I think i got same issue. thought we fixed it, but no. It runs great on foggy rain days and shitty on nice days.
after cleaning my carb im having the same problem if i slam the gas down it dies on me but if i start gassing it slowly it runs fine all the way, its only when i slam on the gas that it dies.
87-250sx
86-300es Big Red,The Beast
85-250sx Tiny SwampThing
85-250es Big Red
84-70 ( My Sons Bike )
not enough fuel in the bowl? adjust the float level back to spec. and then play with it abit to get running the best
I had my 200s foul plugs like crazy then I would have to wire brush them and put them in it ended up being the wire to the spark plug after I replaced that it worked great. Also check for water in the gas when that happens to me ifi give itgas fast it just dies I would have to rev it slowly i just splashed a little bit of gas line anti freeze in splash around the tank and let it idle a few minutes to get it through the system and then it works perfect again.
my 185s did the same exact thing. I adjusted the clip on the needle and that fixed it.
well, it ran pretty good for the weekend... was having problems at times if I gave too much gas too quick. I will try checking the color of the spark, I think I have an actual tester.
Its always hard to start when the engine hasnt ran for a day or two, then after that, it either starts first pull or takes a bunch.
I am leaning more towards an electrical problem, but I will let you know what I figure out.
Thanks for all the replies!
Could be some water collecting in the float bowl...but pull your mag off and knock/sand all the rust off of it..
