Thread: 84 kxt 250 parts list
    does any one know if there are any types of exploded views or manuels for the kxt? i have a 84 kxt 250 but it's been sitting for a while and want to give it a good over haul. what are some major things to look at since its been sitting for a long while? any info would be great!i am looking into new clutch, check piston "is there a sleeve?" and clean carb.
    85 tecate original, stock
    for sale :84 tecate complete,8inch+swingarm, complete rebuilt engine,dg type2 , ,douglas aluminum rims with realtors, new stator and fly wheel.
    70 something hodoka ace 100
    84 lt185
    i also noticed when i put it into gear and push it the gears grab, when i push it in gear with the clutch engaged the gears still grab. the clutch feels good , not to loose not to tight.are the clutch plates or springs bad/worn?any info would be great!
    thanks,
    dan
    84 lt185
    Southern MN
    1,875
    I have the exact same problem with my clutch on the Tecate. If you get it running, it wont enguage, trust me. I havent figured it out yet, but a good way to start would be to take off the right side engine case, and the clutch will be right in front of you. I have been hearing a lot about non working tecate clutches latley.
    If you havent gotten it running yet, you should be sure that it has spark before doing anything else. As everyone knows, the flywheel and stator are a common problem to go out on these kawasakis, and new from ricky stator, they will cost around $250, but are supposably really good. roll
    About the sleeve, I think it is permamently pressed in, so if it has a lot of scratches, you would probly be better buying a diffrent used sleeve. I dont think you can bore them out, but I may be wrong. If it has good compression, it should be okay. It helps to give it a quick hone, which gives a little more compression.
    A good website I found for diagrams was buykawasaki.com ,, they have onling diagrams that you can enlarge. I hope I was some help to you. Peace. )
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    yes i need a fly/stator. i tore the motor down the sleeve is ok"no scraches" but the piston has some fine scraches so its gonna have to be replaced!
    schematics
    Here's a link to Kawi schematics. Click on "view parts diagrams" on the left side of the screen, then select "ATV", select year, skip over to the last block and select "Tecate"
    http://www.buykawasaki.com/Default.asp?
    83 185s *Now belongs to my nephew*
    83/84 200x
    85 Tri-Z
    85 350X
    85 Tri-Z Parts Donor
    88 Yamaha Moto-4
