Results 1 to 15 of 27
Thread: 350x header pipe removal question
    Dec 2009
    BFE
    1,202
    I'm wanting to get a new exhaust system for my 85 350x, prolly a black or chrome DG (yes I know there not the greatest pipe out there but they have to be better then the 85 stock exhaust system) I have a consern about getting the nuts off of the exhaust studs with out destroying them( they are bad rusty) Does anyone have any tips or tricks to get them off? They seem really awkward to get a socket or a wrench on them. What have you guys used? Is it better to try and remove them when the pipe is warm? I plan on using alot of liquid wrench for several days before I give it ago.
    "I'm Kind Of Like The Turtle Man Of 3Wheelers."
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Oxy Acetylene, liquid wrench does nothing............
    ctbale is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    anchorage alaska
    289
    yea, if your lucky the stud will unscrew out of the alum head, stud and nut on mine usually just stay together, then just screw in a new stud. I use the silver anti-sieze on the stud/nut. like DC says, get that alum hot hot hot, I smack the stud like a nail just to shock it a bit too!
    Oct 2007
    Minneapolis mn
    4,067
    ^^ As stated above works... But what I have come to discover... The worlds best way to remove a rusty nut from an exhaust stud, is a dremel. Using a small cutoff wheel, cut the side off of the nut, ever so carefully until it splits right next to the stud... Then you can back it off with a pliers, and reuse the studs with fresh nuts and high temp anti-seize compound...
    Dec 2009
    BFE
    1,202
    Well, bad news I think I screwed up bad I tryed to unbolt my header pipe and one stud cam out with the nut rusted on and the other 3 broke off with about a half inch of thread sticking out. Where do I go from here? Should I try to weld a nut on and try to back the studs out? If I use heat do I try to heat the stud or the head? I know the head is aluminum how much heat is it going to take? Im very flustrated with myself my 350x is my most prized possession hate to think I screwed it up
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Finger Lakes Region, NY
    613
    I would place a nut over the worse stud flush with the head. Be sure to get the stud as clean as possible before trying to weld the nut on and use a clean nut. Make sure you have good penetration to where you see the top of the stud and nut have somewhat "puddled" together in the center. I would wait a few seconds and then while it is hot back it out. That should do it.
    ...the branch cannot bear fruit of itself, unless it abide in the vine...
    I'll eat a head on you tube if it works......
    The worst thing is when the studs come out, they normally do not leave a clean hole and need a helicoil to tighten down well again; Of course at this point it's best to go stainless.
    You may have to take the head off, I have seen the casting bosses snap off when removing a stud rather than milling/drilling it out.
    Worst case scenario, take it out and send it me, I've done dozens of them now.........
    I can't believe people are still doing this. Time after time. Reminds me of lemmings...
    he should have listen the first time.... ahhh well,, guess whats next... snap it off flush,,, and HELP!!!!!!!!!!!!!!!!!!!! LOL
    613
    If you are referring to my suggestion it works fine. I guess it would depend on your welding skills. I use a Hobart Mig and haven't had a problem yet. I suggested trying one first so if he didn't have the welding skill or it didn't work then he could try a different route. Its a lot easier trying one stud than pulling the head.
    if he got the nut cherry RED he wouldnt have to weld ... is his point! and mine... and a few others...conceder yourself lucky if it worked..I do it everyday on dodge exhaust studs...
    ^ YES, tell that to Mr. Hobart...............
    I have 20% luck with that process and never in a head.
    613
    I agree with that 100%. I posted after he broke them. The torches would have worked had he went that route. I was surprised he went on to the other two after the first one broke. Hard to say what tools he has on hand???
    Quote Originally Posted by 2Tim215 View Post
    I was not referring to you. I was the manifold guy at a custom exhaust shop for 2 years. I've probably done the exact process you described hundreds of times. With the cast iron heads you can get away with removing a stuck stud and cramming one back in there. The 350X head is aluminum. It's more than likely the stud is going to take some aluminum with is on its way out, if he can even get it out. Or he'll break out the drill and drill a cock-eyed hole. Then it still needs to be heli-coiled. At the end of the day, the head should come off. I've personally seen some heads that people tried to fix on their own before sending it out to the expert and it makes life harder for everybody and destroys parts.
    Blossvale NY
    4,563
    Whatever you do, do NOT put an oxy/ecetylene torch to the aluminum head! When you put that kind of heat to aluminum, it melts very fast, almost like solder in a propane torch flame, (dont ask how I know). Aluminum's melting point is only about 700 deg farenheit, the oxy/acetylene flame can reach temps over 5000 deg farenheit.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
