Thread: PW50 Motor in Tri Zinger YT60?
    stevensj13's Avatar
    stevensj13 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Willow Springs, North Carolina, United States
    338
    Theres a guy on craigslist that has a PW50 in pieces, but it has a new top end. I am thinking of picking it up for the engine, because my tri zinger engine is in need of a LOT of work and i heard that they are the same engine besides the top end. If I can just bolt in the PW50 engine and run that until i get my other engine finished that would be great! Would the PW50 engine fit?
    Dec 2010
    shelbyville mi
    61
    iv heard that aswell
    1984 250r
    300 big bore
    bassinni pipe
    boysen reeds
    34mm pj
    k&n pod
    1986 atc200x needs help
    2 banshees 1 for trails 1 for dune/drag racing
    stevensj13's Avatar
    Jun 2011
    338
    Well i recently pulled the zinger back out of storage and am still curious about this. Does anyone know if its a bolt up swap? And also, do i need the drive shaft from a pw50 too or are they the same too?
    My baby - 1984 Honda 200X, Clark Desert Tank, Supertrapp exhaust.
    Dec 2010
    S.E. Illinois
    1,178
    should be a direct bolt-in. shafts should be the same too. also there's a few moped's that share the same motor and if you can find a mj (Towny) motor you can have an auto 2speed trans (not exactly a direct bolt-in though for the 2speed).
    74 HONDA ATC 70
