Just got this 1984 ytm225dx in a wheeler deal, and it's pretty beat, oil drail plug is so ripped up from the previous idiot of an owner not using the right size wrench or socket, then after it was stripped tried numerous times with vice grips. Some more bad stuff about it I seen was obviously the motorcycle tire and front end, that has to go pronto. It had the hub welded to the axle and the weld failed (whoever welded it sucks completly at life, let alone welding). The plastics are struggling to hang on when the wind blows. The seat looks as if the fattest person in the world rode the crap out of it, I see more foam exposed then anything. The oil is easily an inch OVER the full mark on the dip stick. It has electric start but the wires and stuff are disconnected or missing.
Now the good, It does run, 1 or 2 pulls ( I don't let it run long need to drain the oil). hahhaha thats it just that is runs. But I am determined to get her ridable and looking alot better than that (I have a 1983 ytm200 for parts I am going to try to fabricate on: plastics, front end, rear axle (unless I buy Kirby's axle, I hope. waitin for his reply). I'm excited to get the project rolling and will post as it happens. Getting pics asap.
1987 200x -First Trike-
