Results 1 to 11 of 11
Thread: Honda 110
    Jun 2011
    Minnesota
    Honda 110
    Hi I am new to the three wheeler world and i have a 110 that is stuck between 1st and 2nd gear, not high or lo range. I am wondering how i get accese to the gears to investigate the situation at hand. Which side of the engine to take apart what i have to take apart to get to them or if i have to pull the engine and need any special tools for the job. Thanks
    6,813
    Pull the right side clutch cover and look at the shifter paw stopper as its prob broken or come loose . You dont need to remove the motor to check this .
    Nov 2006
    Huffman TX
    891
    i believe its the right side you pull off... the shift forks might be damaged.
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    Grande Prairie, Alberta, Canada
    96
    One note, if you do tear into that clutch you'll need a special tool. Not sure what it is called but it kinda resembles a socket with 4 "pins" protruding from it. The tool should be available from honda, if not check out DrATV.com. Actually, check out their site anyways, it's very good. I'm not sure if you could remove that nut by means of a more "homebrewed" method as I've never tried. Good luck, hope it's something simple.
    Nov 2006
    Huffman TX
    891
    Quote Originally Posted by H2Sbass View Post
    You dont need no special tool, for the clutches?? I never used no special tool, all them "special tools" only make the work easyer, there is allways a hard way/original way. how do you think they made that "special tool"? by doing it to much the hard way
    TRIKES
    82 185s-SOLD!
    82 250r-SOLD!
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    Quote Originally Posted by three_wheelin45 View Post
    He is refering to the 4 prong socket that removes the clutch nut. With it you back the nut off with am impact wrench and continue with repairs. Without it, you try and cram pennys in gears or wood blocks in the sprockets and you beat on the nut with chisels and punches. I prefer the "special tool".
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    Jun 2011
    Minnesota
    yes i have seen this tool working on my snowmobiles they can be easily made from an impact socket the correct size and a little manipulation with a metal blade and a file and there ya have it
    Sep 2007
    100mi west of Chicago
    3,582
    Yes they are easy to make with a Dremel. It's not pretty but it works like a charm
    Rob
    Nov 2009
    N Hollywood/ CA
    588
    Three wheelin45,
    Doing it the hard way! Me likie. Old school stuff.
    jr315rn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2011
    rochester ny
    288
    what size ?
    96
    Don't get me wrong, I have plenty of experience with "make it work" tactics. My god you should see my truck, Its made cops actually laugh because of some of the bush inspried repairs. When it comes to these old bikes though I say try to do it right cause there is nothing worse than mangling a part that is no longer in production or hard to find. It's bad enough trying to find metric hardware to replace broken or stripped bolts/screws, and I'm from a country that "uses" the metric system. That modified socket looks pretty acceptable though, I'm more knockin' on the idea of pennies and punches. Not sayin' they won't work, just riskier that's all.
