alright here we go, this is what we got to work with
any ideas? what should i start with? who should i talk to for parts? etc
any help jake
any help jake
shortline 10 has some 110 parts.... what does it need?
1985 Honda BigRed 250ES
runs good all original
Restoration in progress:
1980 Honda ATC 110
1985 Honda ATC 250SX
1982 Honda 200ES BigRed
1984 Honda 200S
1984 Honda 200S parts bike
1985 Honda ATC 110
1983 Honda ATC 110 parts bike, runs but smokes
Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
What are you looking to build? Full teardown and rebuild? it looks amazing cosmetically already. Looking to do a bore over and just replace all the internals like valves etc?
'86 200x Always ready to ride
ive got some big bore 56mm pistons the largest you can go and a jsc frame for sale
85 Atc 70
86 Atc 125m
85 atc 350x
86 atc 250r
86 Atc 250r TT build
85 Big Red bought brand NEW
2012 Honda Goldwing Gl1800
you should totally build a flat track trike
it doesnt run atm there is alot of rust in the tank, the carb is so far gone. would like to bore and stroke and just make it look realy nice just a little project now that im out of school for the summer
anyone got any parts or stuff u think should be in this build let me know im up for anything![]()
any ideas?
PM Shortline, he has a ton of parts. Motoman said he has some stuff as well.
RIP Ninja!
Trike Fest 2011, 2012 Vet!
Trikes Currently Owned:
87 Big Red 250es
83 Honda 200s
81 Honda Atc 70
(4) Suzuki ALT 50's
Yamaha YT 60
Carbs an easy clean. Dissasemble, soak in gasoline, blow clean, re assemble. As for the gas tank I would just buy a plastic one really.
I agree, start with the carb. Does it have spark? Clean the carb and fire it up to make sure the tranny is shifting etc. Then you can decide where to go from there.
...the branch cannot bear fruit of itself, unless it abide in the vine...
i cleaned the carb THREE TIMES! cleaned the tank out with mucrict acid, made the tank look really nice. one of the intake bolts is strippednow what?
Intake bolt connecting the intake to the carb? Or bolt connecting the intake to the cylinder? If its the one connecting it to the carb, that happened to me too. I just unscrewed the stud, threaded a longer bolt through and put a nut on the other side.
If its the bolt holding the intake to the cylinder, you will probably need to re-tap it to a larger size. But there may be some old-school trick that I don't know about..
1987 Honda 250es
1987 Honda 250sx
1986 Honda 250es
1985 Honda 110
in to the cylinder....
Drill through the broken section of bolt (smaller diameter than bolt) the heat up cylinder with a small torch (propane will work) then use an extractor to grab the bolt and turn it out. Extractors can be bought pretty cheap.
'74 ATC70 (stock for my nieces)
'84 ATC70 big carb, race cam, and piped (big boys little toy)
'84 ATC125M
'85 ATC125M
'85 ATC185S (200X carb and pipe)
'83 ATC200X (my first trike ever, avatar pic)
'85 ATC200x
'85.5 Tri-Z 250
'85 ATC250R
'79 CJ7 w/351 Cleveland
'77 XL75, '78 XL125
'88 Katana 1100
'00 King quad
'05 LTZ400
