my 1984 Honda Bid Red 200's lights are reversed. When I throttle up, the lights dim. Including the nuetral/reverse lights. What could be the problem? Something in the stator but why is is reversed
1988 Honda TRX250R
fmf pipe, ct national port airbox lid removed worcs front shocks renthal bars maxxis razr's
1985 Honda Big Red 250ES
1984 Honda Big Red 200ES
1982 Yamaha Tri Moto 175
Please Check Out My Youtube Channel
http://www.youtube.com/watch?v=Mbwd1...feature=relmfu
my warrior was like that before i put a battery in it. it fix my problem.
either a bad ground or a NFG battery
check all of your wiring connections before tearing into any thing, look for moisture build ups and add new dielectric grease as needed. do you have a spare cdi you might be able to try? Also open the pulse generator cover on the motor is the one that says CDI on it and clean out the red dust. And last but not least check the alternator/ stator before tearing it open.
