Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: Thanks Look!!
    up-tyte is offline At The Back Of The Pack Arm chair racerFirst time rider
    Springfield, MO
    149
    I just replaced the bearing in a 86 sx. Harbor Freight has a cheap metric allen set that goes to 17mm, on sale about $13. I ended up just replacing the bearing itself as the race seemed to be okay and was not scored or scratched. I saw in the ebay pic the two metal caps, those are not mentioned in the manual it looked like part of the frame. The swing arm bolt is what torques to 12-14 ft lbs and the lock nut torques to 72-94 ft lbs. I modified a socket to get the lock nut out and will have to make a wrench out of a piece of pipe to tighten the lock nut.
    Jan 2011
    mifflinburg
    525
    Ok, Yes DJ i was going to cut it On that side, Right where u said to, Going to get Blades soon, and going to try it, I hope it will work, Not sure what u mean by it might have enough room since my insides fell out,
    Maybe i will go get a 17mm allen wrench and give it a try with that, Maybe i can get the pivot bolt out with the nut still on it.
    Thanks guys
    Pacific NW
    4,255
    Quote Originally Posted by Headsup View Post
    Thanks guys
    see?
    the swing arm needs to rock from side to side to get past the stub axle and the bearing mount on the driveshaft tube on the other side..
    Both stick out maybe an inch or so.
    I'm trying to think of an analogy..maybe like picture an open end wrench that's too big for a bolt...and it can slop back and forth .
    The 'right' way is to back out the axle with the lock nut on it to give you that 1/2 inch or so that you need to get the swing arm to come out.
    Now since your bearings are simply gone, you may have enough slop from side to side for the whole swingthing to come off without cutting the funny bolt.
    You may also be able to destroy the bearing on the opposite side driveshaft tube to give you a little more room too.
    It's just a sheetmetal caged roller and may almost fall apart anyway.
    If you can't find a 17mm allen wrench, any bolt with a 17mm head will fit in there too.
    Don't feel bad,
    We stared at our sx project for a week or so before we got mad and threw everything we had at it.
    Just aggravated enough to take one good solid swing at that nut with a 3 lb sledge and a good tool steel punch.
    It helped that we had nothing to lose at that point, so desparation breeds
    invention.
    Just try prying the swingarm side to side before you cut anything.
    it may just have enough room to fall off. and if not, it will be annoyingly superclose.
    Springfield, MO
    149
    You might be able to drill a hole in the lock nut to relieve some pressure. Just drill at a notch and then pry it lose and take it all out together. That might be easier to try than cut the swingarm bolt.
    Jan 2011
    mifflinburg
    525
    Nope swingarm does not move side to side hardly at all, I think i know what your saying though,
    On the drive shaft side there is An inch or so of over hang? Like a Bar That the barrings would go onto. i think i understand, Last thing i can try to to cut a half in to andf inch out of that pivot bolt, Then try to remove it ounce the swingarm is off..
    Jan 2011
    mifflinburg
    525
    LoL, Wuhahahaah, Cut the pivot bolt off, Pryed the Drive shaft back, Pop Off came my swingarm, Thanks To every1 here!!
    Now i just need to get the Bolt off my swing arm, Wondering if they sell a 17mm allen wrench, That is big enough to get some good Pull on it,
    Everything Thanks guys, Mucyh appreciated, Finnally the swingarm is off, Now just the bolt out,
    Any ideas on a good way to remove it? Drill re tap or any tool you think that would work?
    Pacific NW
    4,255
    Quote Originally Posted by up-tyte View Post
    I love that idea.
    Jan 2011
    mifflinburg
    525
    Getting it slowly, Taking a hacksaw and Cutting threw the Pivot bolt, Taking about a half in. chunck out at a time, Hope this works, Have a new pivot bolt on its way, Also going to get more blades tomorrow, The one i have gave up.
    Think that will work? Or will it screw my threads up inside on my swingarm? Im going to be gentle as i do not want to buy a swingarm.
    Aug 2005
    Lockport, NY
    2,395
    Check this thread out. Lots of good homemade tools to get that baby apart.
    http://www.3wheelerworld.com/showthr...o-save-a-Trike
    Jan 2011
    mifflinburg
    525
    Ok, Im going to read that thread, Thanks, I started to cut the bolt out, Like long ways to take chunks out at a time, But the pieces i cut, DOesnt seem to want to come out, No idea. Ima try to get more PB and Soak it, Hacksaw it again, Trying to be careful not to hit the Threads for the swingarm,, But i have no idea.
    Springfield, MO
    149
    Did you try drilling the lock nut to take it off first? You should be able to just drill it on both sides, same as cutting it with a saw but drilling instead of cutting. Just don't drill any deeper then the nut is thick, I think about 3/16" in the notch. Once that is off I bet the bolt will just turn out.
    Jan 2011
    mifflinburg
    525
    LoL, Cut it, Took pressure of ed a little, Then walla nut spun off, Got the bolt out, Threads are Intact, Bolt is on it way with my Bearings, Thanks You All!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    glendive, montana
    1,822
    glad to hear everything went well in the end
    Jan 2011
    mifflinburg
    525
    Thanks if it wasnt for You really, I got threw it, i am Going to make a video, and take some pics for you all when i get my Bearings, Thanks again, Just look for pics soon,
    Thanks a ton again.
    What a person can do when their is no other option
  15. #30
    Springfield, MO
    149
    Glad to hear you won the battle.
