Results 1 to 3 of 3
Thread: Help 85 & 86 250r guru's
    davham's Avatar
    davham is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    211
    I need to know the differences between the 85 and 86 model. I know the headlight plastic and seat cover but what about things like frame, swingarm, forks, shock? Or will everything pretty much interchange? Thanks
    atc86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bangahore, mi
    306
    I believe the front forks are smaller diameter. The swingarm, bearing carrier and rear brake bracket are different. probably axle also. Carb is different style same size.
    May 2003
    So. Cal.
    85
    85/86 difference
    So far as I know..... Rear axle & bearing carrier (one has tapered bearings, the other dual row, if I remember it correctly); rear caliper mount;, rear shock lower linkage; rear sprocket hub (86 has larger mounting bolts); rear sprocket (one has countersunk holes, the other doesnt, sorry cant remember which one had which); swing arm (85 has 2 carrier clamp bolts, 86 has 4); front forks (85 has 2 springs inside each leg, 86 has one, far as I know the fork lengths are the same); seat (86 says "ATC", 85 says "250R"); engine color (85 is black, 86 is dark grey I think); I'm not sure about the headlight plastics being different, so far they look the same to me; some of them had reflectors on the forks too (maybe Canadian models??); 86 rear ends interchange with the TRX-R, 85's dont (for the most part). That's all I can think of off-hand. Please feel free to correct any info thats wrong .
