Well, where do I begin. I found my YTM200e under somebody's deck, been there for years and years. Entire fuel system jammed up. Cleaned petcock, flushed gas tank with new gas, put on a newer working carburetor, put in a new air filter and changed the oil. Engine fired right up without a hiccup, let it warm up and got the oil flowing, ran extremely well with no smoke. Rode it around my yard for a bit, with the intention of changing the oil and rear fluid once warmed up and moved around a bit. After about 20 minutes there was a little cough from the carburetor and she sputtered and died. Started her back up and all seemed well, but an increasing problem arouse. Under load approaching full throttle the bike would severely sputter and if more throttle is applied the bike just dies like it lost spark or its will to live. If you cut back on the throttle she comes to life. I've tried adjusting/re-cleaing the carburetor to no avail. I took the fuel cap off, no difference. I disconnected the fuel line from the carburetor to check fuel flow, it flows freely and fine. I disconnected both the key switch and handlebar stop switch thinking it may be electrical with no change. I changed the spark plug coil with no change. I changed the spark plug with no change. I sprayed contact cleaner around the carburetor intake looking for an air leak, but no change. Anybody else have this type of problem before? Why all of a sudden would it hiccup and run crappy now? Could I be looking at a CDI or trigger coil problem? Any help would be greatly appreciated, really looking foreword to taking her out on the trail.
