Results 1 to 9 of 9
Thread: 200x vs 250r forks
    skidoo99 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    nh
    267
    200x vs 250r forks
    well i found out the hard way after polishing my 200x lower triple tree which i planned on putting my 84 250r shocks into. turns out, they are a different damn diameter. crap! has anyone ever been able to open up the 200x triple to fit the larger fork tube??
    thanks in advance
    Rollingmenace is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2008
    Colorado
    224
    ive seen it done on first gen r tripps to accept 2nd gen forks... im sure you could open up the 200x stuff as long as there is enough meat there
    82 ATC 250R (AS $ Crusher.. Project 450 swinger)
    84 ATC 200X (Project Blackout) Hers
    86 ATC 250R
    86 TRX 250R (The Golfcart)
    87 CBR 1000F SSSA STREET FIGHTER
    95 NINJA 250EX
    My Feedback http://www.3wheelerworld.com/showthr...-Rollingmenace
    Nov 2010
    nh
    267
    well after a little prying and such, its a no go. if they were to fit the bolts wouldnt thread in because of the angle.
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    Old racers trick from the 80's. Running 83-84 forks on an 83-85 200X. Need to bore triple clamps from 33 to 35mm.
    Curtis.
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    Nov 2010
    nh
    267
    curtis that is great news. ill measure the forks first but are you sure its 35mm? thanks
    Sep 2008
    Colorado
    224
    have to take the tripps to a machine shop and get em bored
    86 ATC 250R
    95 NINJA 250EX
    Sep 2008
    845 New York
    2,302
    How is that 250r doing? Ive got that jetski pretty much figured out
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    Have a ball getting them bored.... Triple clamps are not easy to hold due to there "cast" design.... Set up time isn't cheap, the boring operation is chicken.....
    I'd find a way to use the R triple clamps and make my own steering stop.
    Those forks are 35MM (same size as...) which fit right in the 85/86 350X triple clamps if that helps (No rake in the 350X triples). Your stock forks are 33MM and boring them is a mere .040 wall thickness, yet nothing easy.
    Boring your triples weakens them/thins them, and isn't easy or cheap unless you have machinist friends. How they match that angle and do them inexpensively is beyond my comprehension.....
    But, you also have to check your rake issues also. IDK what the
    Nov 2010
    nh
    267
    hmmmmm, so does anyone have a spare lower triple without the tapered bearing i could buy?
