Results 1 to 9 of 9
Thread: 200x question
    98600xc's Avatar
    98600xc is offline At The Back Of The Pack Arm chair racerFirst time rider
    minnesota
    150
    200x question
    Can you put air in the forks through the valves on top to stiffen them up?
    1982 honda atc185s- for sale-p.m. me if interested
    1985 honda 200x
    Jan 2011
    Brazil, Indiana
    2,087
    I suppose you could probably put a pound or two in them, but the valves are meant to equalize the pressure inside the tubes with the outside air. Why not just put in a little heavier oil in them?
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Apr 2006
    SE CA Dez in the sandbox
    894
    go to 20 wt. oil
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    O.C., Oregon
    921
    If you wanna blow out your seals then yes but the shreader valves are to equalize built up air pressure that comes from riding
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Texas
    137
    The service manual states that they can be pressurized up to 10 psi, but be sure to use only a manual air pump (like a bicycle tire pump), or you'll blow the seals.
    O.C., Oregon
    921
    Quote Originally Posted by RapidRick View Post
    go to 20 wt. oil
    Like rapidrick said just go to a heavier oil and a maybe a 1" or 2" PVC spacer and you'll be much happier and you won't blow any seals
    2017 YZ 250x- Braap
    98600xc's Avatar
    minnesota
    150
    Well, Im new to the 200x's so how do you change the oil and where do you put spacers? sorry for the dumb questions!
    1985 honda 200x
    Crest California
    3,014
    Gotta pull the forks off and begin the dis-assembly. While you're at it, you're going to want to pickup new seals and gaskets
    LED obsessed
    2015 Yamaha FJ-09
    Jan 2011
    Brazil, Indiana
    2,087
    heck if you are going to have to tear the forks apart, you might as well try 5 pounds of air in them to see if you are going to like stiffer forks or not. What is the worst thats going to happen, you blow the seal and have to replace them any ways?
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
