Well guys alot of yall know I have been messin with carb problems alot. The stock carb on my 81 185s was wore out. I bought a chinese carb off of ebay and it is junk.
So now I am trying to get a good used 200x Carb off of ebay. I was wondering what are all the stock settings on a 200x carb. Im looking at the 83-85 200x carbs.
I just got the 185s back together today. New valves, valve seals, valve job, timing chain, guide, tensioner. It has a 200 cylinder on it. While apart I found it is bored 65.5mm with a higher compression piston(I guess 10.25?) It has a pretty good sized dome on it with reliefs for the valves. Fairly hard to pull over. Also full DG exhaust. Yall think the stock 200x jetting will work on it? I have a pretty good collection of jets from trying to dial in the other two carbs.
Thanks.
