Thread: Good Bead Breaker?
    Sep 2003
    Brookville,PA
    1,408
    Good Bead Breaker?
    Does anyone have experience with the cheap($100.00 to $150.00) atv bead breakers? What is a good one, that actually works?
    Sarnia, Ontario, Canada
    3,415
    A trick I learned once..
    Remove the wheel and lay it flat on the ground on some wood, remove the valve stem, place a 4ft long 2x6 like a ramp from the ground to the edge of the rim. Using a spotter person to tell you when to stop, use your car and drive slowly up the 2x6 and let the weight of the vehicle pop the tire off the bead. Back down, get your spotter to rotate the rim and repeat, then flip it and do the same on the other side.
    Then muscle the tire off the rim with soapy water..
    Maybe not for people to want to change tires all the time, but for occasional Joe it works and is cheaper than a bead breaker..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    bigred44's Avatar
    bigred44 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    Ithaca Ny
    361
    http://www.ntxtools.com/network-tool...SI-HH-419.html
    I've had good luck with this type. Might be able to find one cheaper somewhere else.
    '84 ATC 110
    '84 200x
    '85 350x
    '86 125m
    '03 Shadow ACE 750
    '05 Brute Force 650
    O.C., Oregon
    921
    Exactly what i do and it works like a champ!!
    Quote Originally Posted by dougspcs View Post
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Mar 2011
    Ohio
    236
    I always drive onto my tires to break the bead too
