Thread: This is ridiculous
    Des Moines, IA
    1,303
    This is ridiculous
    I seem to be plagued with bent front wheels on my ATC90. It doesn't get beat on, so I can't figure out why it happens. I replaced it with another split rim I got from someone here a couple years ago, and now it's wobbling again.
    How hard can it be to fix? Just need a new rim, right? So I found a one piece Carlisle 3 on 100 rim on ebay that looked like it would do the trick. Found that the bolt holes are larger, so my old style hub wouldn't center. Back to the drawing board, bought a newer style ATC90 hub that has a centering ring and hopefully prevents the problem with the loose bolt holes. Darn thing still wobbles. So it must be the tire, right? I went to northern today and bought a brand new tire. Not to say that their tires are super wonderful, but should be fine for this machine. The darn thing STILL wobbles! Watching it go up and down is nauseating.
    When I was trying to seat the bead, I pumped it up to almost 20lbs. The only thing I can think of is that I ruined the new tire and it's misshapen due to too much pressure. Oh, and there is a tube in it, because the bead wouldn't seat on these oddball rims.
    How many hours can you spend on something that should be so easy?
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    6,811
    Very common problem with the balloon tires to be EGG shaped a little . I bought a couple of those northern 22x11x8 tires and both are wobbley . Better off buying a good name brand tire like Duro . Not sure whats going on with your rims .
    Crest California
    3,014
    I am running a Cheng Shin knobby on the front of my 110, and it doesn't wobble one bit after 6 years of being there.
    LED obsessed
    2015 Yamaha FJ-09
    Des Moines, IA
    1,303
    Mostly I was just venting. I wanted the thing back together right away, which is why I bought the Northern tire. They worked fine on the back of my KLT110, but I knew they weren't very good quality. I think the Cheng Shins are actually a lot better!
