So I have a manual ordered and it should be here by the end of this week, but I was wondering if anyone could help me out with the break in procedure so I could get started on it. Any help would be great![]()
TF 09, 10, 11 Survivor
81 250R- DG pipe,DG silencer, DG head, DG boost bottle, 34mm flatslide carb, UNI filter, Works shock, Nasa +5 axle
85 Tecate-
, but Airfoolers RULE!!!
Lots of methods. Some say to let it idle for half an hour, then let it cool completely, then repeat once more then give er hell.
I like to let it idle for half an hour, then let it cool, then idle for half hour, then cool, then gently ride for 10 minutes, then progressively get harder and harder on the throttle.
LED obsessed
2015 Yamaha FJ-09
I have an oem 84-85 Tecate service manual and the only thing it says pertaining to break in is:
"NOTE"
Whenever the piston or cylinder has been replaced with a new one, the motorcycle must be broken in the same as with a new machine.
I don't have an owners manual, but I assume that is where the break in information is.
Rides:
1982 ATC70 (Lifan manual 125)
1987 LT80 (piped, widened)
My feedback thread
RIP Trace.. Godspeed.
Break in procedure from the owners manual:
LED obsessed
2015 Yamaha FJ-09
I just give them a few heat cycles and it should be good .
So he should ignore the manufacturers suggestion? I'd think they would know how to break in their engines, seeing as how they made them....![]()
LED obsessed
2015 Yamaha FJ-09
Can someone post the link to the oscarmayeratcmanuals.org or .com site, it was started by a member here and it goes over everything that you need to know about engine break in and storage and there's also a handful of atc manuals on there.
